Only a Moderator can add other Moderators to the Review.
To add Moderators, go to the
Review tab of Jama Software and select the
Table button on the far right. You will see a list of all your reviews and will be able to confirm your role either as a Moderator or as a Reviewer.
Select the
Update Moderators for this Review button next to the Review for which you want additional Moderators.
This can also be done while in a review via the
Tools menu.
You will be able to search for the users and add them as Moderators by clicking their names in the left. They will automatically appear in the right.
In case you need to remove a Moderator, click the corresponding
X on the list.
If you need to add Reviewers or Approvers to the Review, this can also be done through the Review's
Table > Edit this Review button.
This will open the
Edit Review Wizard.
In the
Select Reviewers section, you will be able to add Reviewers.
To set Approvers, you need to select the
Check icon corresponding to the user you want as an Approver.
The green
checkmark will indicate which Reviewers can provide approval or ask for a new revision.
#ReviewCenter
