Setup Instructions Prior to Running Data Exchange
By Iman posted 12-05-2017 13:51
Hardware Requirements
Windows
  • Minimum Pentium 2 266 MHz processor
  • Minimum 2 GB RAM
  • Minimum 2 GB Disk Space
MacOS
  • Intel-based Mac running Mac OS X 10.8.3+, 10.9+
  • Minimum 2 GB RAM
Software Requirements
  • Java 8 Runtime Environment available here: Download
Jama Environment Setup
REST API Enabled
Ensure that the REST API functionality is enabled on your Jama instance. You can check to see if the REST API is already enabled by navigating to yourjamainstance.com/api-docs and verifying that the Swagger documentation is available. Contact Jama Support for assistance enabling the REST API, if required.
Installation
  1. Download the Data Exchange executable .jar file from the Professional Services community library
    • If you don’t have access, contact your Jama Account Manager
  2. Create a local directory for the Data Exchange executable and related files to live within, and move the .jar file to that directory.
  3. Create a directory titled Util inside the directory created in step #2 that contains the executable .jar
  4. Place the Data Exchange license provided by your Professional Services consultant into the Util directory created in step #3.
