Data Exchange Release Notes
By Iman posted 12-11-2017 00:00
Data Exchange 2.1.1
Release Date: December 21, 2018
New Features
Resolved Issues
  • Improved rich text handling of table and object tags
  • J2J will now use a random UUID to populate ReqIF IDENTIFIER attributes if no value is present in the Unique ID field. previously the Identifier was populated with the Jama item api ID. This can cause conflicts when moving between two jama instances.
  • Resolved an issue that caused ReqIF attribute value definition elements to have duplicate identifiers when an item type is exported as both a specification and a spec object.
  • Resolved a defect in the mapping generator that caused a NPE if the source ReqIF file contained datatype definitions with default values specified.
  • Added error handling to the mapping generator. Now the user will be notified if something goes wrong during mapping generation.
  • Resolved a defect that caused items to fail to post if the description field was null.
Known Issues
  • performing multiple J2J import/export cycles may result in an invalid relationship map that causes a NPE during export.
  • fields added to an item type in jama after an import cannot be exported with a mapping.
Data Exchange 2.1.0
Release Date: December 5, 2018
New Features
  • ReqIF Import Validations: there is now two new ways to validate your import before actually running the import. There is a pre-flight validation that is automatically run when you select a source ReqIF file to be imported. This pre-flight report will run quickly and give you basic information on your ReqIF source content. In addition to this there is now a validation button added to the import view. This main validation will validate the source ReqIF file and a mapping file. This validation report will determine if the mapping is correct and will ensure that the ReqIF identifier are present in the source content and also will look into Jama Connect to see if all the item types, item type fields and relationship types exist.
  • Performance: Get actions on the API are now completed asynchronously.
Resolved Issues
  • XHTML fields will be exported correctly without body tags, or escaped HTML entities.
Known Issues
  • Clicking login with no password entered in the password field will prevent any future clicks of the import button. To log in once this has happened, close and reopen the Data Exchange.
  • Complex Jama 2 Jama Hierarchies produce invalid ReqIF files. This is because Identifiers are duplicated between when a set or component is captured as both a SPECIFICATION and a SPEC-OBJECT
Data Exchange 2.0.6
Release Date: November 16, 2018
New Features
  • Support for csv
Resolved Issues
  • Resolved an issue causing dropped items when certain special characters were encountered.
Known Issues
  • html elements with style attributes may not parse correctly, fields will still be posted, but styling may be lost.
Data Exchange 2.0.5
Release Date: October 8 2018
New Features
  • Added the property "defaultUniqueFieldName" to the jama.properties file.
Resolved Issues
  • xhtml object tags will no longer self close.
  • Jama to Jama will now support more complex hierarchies for import and export.
  • Improved support for ReqIF files that are missing line breaks.
Known Issues
  • Self Signed SSL certificates are not supported currently.
Data Exchange 2.0.4
Release Date: September 14 2018
New Features
  • Added interface for user to define global settings. This includes a new default unique id used for round trips. Also moved settings from the settings menu dropdown into this new global setting form.
Resolved Issues
  • Resolved null pointer exception with parsing html documents.
  • Resolved issues which skipped items on Jama to Jama import.
Known Issues
  • XHTML documents that use style tag with a font-family list may not parse correctly. IF the tool is unable to parse this then this item is skipped.
Data Exchange 2.0.3
Release Date: August 30 2018
New Features
Resolved Issues
  • Resolved an issue that was truncating strings over 255 characters if they were being mapped to a rich-text field.
  • Relationship groups are now exported.
  • Updated error handling messages to be more informative.
Known Issues
  • Please close and re-open the Data Exchange between each import or export. There is a known defect that can sometimes cause memory to not be cleared between runs, which can cause mapping issues.
Data Exchange 2.0.2
Release Date: August 27 2018
New Features
  • Minor performance optimizations
Resolved Issues
  • Limited mapping now works on export as expected.
  • Resolved issue with un-populated/absent 'LAST-CHANGE' ReqIF field.
  • Fixed project selection duplicate issue.
  • Exported images now have a valid closing tag.
  • Resolved an issue that was truncating strings over 255 characters.
  • Added support for XMLNS headers.
Known Issues
  • Relationship Groups may not be exported.
Data Exchange 2.0.1
Release Date: August 2 2018
New Features
  • Mapping UI provides a cleaner and more intuitive interface for creating and modifying mapping files for both import and export.
Resolved Issues
  • NULL pointer exception introduced in 1.5.3 that would occur while processing html strings.
  • Licensing issue resolved, new license required for use of Data Exchange 2.0+.
  • Relationships that originated in Jama are now correctly exported.
Known Issues & Limitations
  • Limited export mappings export all Jama item type fields to the ReqIF SPEC-OBJECT-TYPE, but only the fields in the mapping file should be exported.
  • Back button on batch import/export screen navigates to the single import/export screen.
  • The mapping UI uses ReqIF identifiers instead of name to create mappings. The workaround is to search for identifier in ReqIF file to get context for what's being mapped.
  • The mapping UI allows you to map incompatible field types e.g. string to integer. This will interrupt execution, requiring the user to correctly map ReqIF data types to supported Jama data types
Data Exchange 1.5.3
Release Date: May 08 2018
New Features
  • Moved the changed deleted functionality (see 1.5.2) to now be configured with the mapping.json file, instead of the jama.properies file.
Data Exchange 1.5.2
Release Date: May 05 2018
New Features
  • Added functionality for identifying items are changed or deleted.This feature will switch the status of a specified picklist within the item and change the picklist option to reflect if the item has been deleted or changed. This can be specified within the jama.properties, and currently is only supported when run through the command line.
Data Exchange 1.5.1
Release Date: May 01 2018
Resolved Issues
  • Fixed issue with ReqIF spec object validations not  being valid on export
  • Fixed minor bug with logs not being reported correctly
  • Removed duplicate logs
  • Fixed UI for the export delivery note
Data Exchange 1.5.0
Release Date: April 25 2018
Resolved Issues
  • Fixed issue with object type being null
  • Resolved issue with empty intermediate folders for export
Data Exchange 1.4.8 - 1.4.9
Release Date: April 16 2018
Resolved Issues
  • Fixed date time truncation issue
  • Fixed issue with folder structure for batch imports
Data Exchange 1.4.2-1.4.7
Release Date: April 10 2018
New Features
  • Added functionality for allowing limited mappings, this feature is used for round trips with the data exchange. When exporting and importing from Jama you can remove fields from the original mapping file to import/export a limited number of fields.
Data Exchange 1.4.1
Release Date: March 09 2018
Resolved Issues
  • Attachments with matching filenames are inspected. If the contents of the files differ, a new attachment will be created and the new file is uploaded to replace the existing attachment
  • ReqIFz packaging no longer includes individual folders for each export, but rather a flat list of exported ReqIF files and associated attachment directories
Data Exchange 1.4
Release Date: March 07 2018
New Features
You can now:
  • Attribute level selection of SPEC-OBJECT legacy IDs
  • Attribute level selection of SPECIFICATION legacy IDs
Data Exchange 1.3
Release Date: February 11 2018
New Features
You can now:
  • Operate the Data Exchange from the command line using a properties file
  • Batch import/export setting available through the user interface
  • Batch support also available for command line execution
  • Component to export converted from text field to dropdown list
  • Data Exchange can now connect to Jama instances that use HTTP and HTTPS protocols
  • Delivery note setting available through the user interface
  • Delivery note support also available for command line execution
  • ReqIFz packaging setting available through the user interface
  • ReqIFz packaging support also available for command line execution
  • For license file auto-detection, license files must now be placed within a directory titled Util in the directory the application jar is located in
  • Last login credentials and setting configuration will now be saved to a local file titled settings.json within the Util directory
Resolved Issues
  • The selected project is no longer cleared when switching between import and export tabs
  • Failed login no longer requires a reboot of the application
Data Exchange 1.2
Release Date: December 11 2017
New Features
You can now:
  • Operate the tool using a valid Data Exchange license. Please contact your Jama Software account manager for more information on obtaining a Data Exchange license
  • Import and/or export ReqIF content with certain fields by limiting the fields associated with a particular SPEC-OBJECT or SPECIFICATION type in your mapping configuration file
Resolved Issues
During a round trip import/export, users are unable to restrict fields through their mapping configurations.
Invalid XHTML tags appearing in ReqIF exports from Jama.
Data Exchange 1.1.5-2
Release Date: December 05 2017
New Features
You can now:
  • Login to the Data Exchange using your OAuth 2.0 credentials
Known Issues
During a round trip import/export, users are unable to restrict exported fields through their mapping configurations.
