The Reuse functionality is an efficient way to quickly copy multiple items and item fields within Jama. If you need to reuse a set of items but would like to only include specific fields or statuses within the item, you can do so within the
Advanced Reuse Options by creating a
Reuse Rule. To create a Reuse Rule, open the Reuse menu by right-clicking a component, set, folder or item within the Project Tree, and select
Reuse Item(s). This will open the Reuse Menu. In the center panel under
Reuse Options, switch to the
Advanced view, and select
Add Rule.
Please note: You must be a Reuse Admin to create Reuse Rules. You can set this permission level under Admin > Permissions.
Selecting
Add Rule will open a new window where you can give the rule a name and a description. Next, you will need to select what Item Type you want this rule to apply to. You can also add related Item Types into the Advanced Rule:
- Reuse downstream or upstream items to the original item
- Relate any downstream or upstream items of the original item
The screenshot below is a rule that will reuse Requirements, as well as any downstream Use Cases of the Requirements in question.
Reuse Rules can include more than one Item Type, by selecting
Add Item Type Rule. If you want items within the rule to be synced to the original items, check
Sync item(s) and share Global ID. If you only want to reuse the items and not sync them, you can
Append a prefix to the names of the copied items to differentiate between the original and reused item.
If desired, be sure to add a space at the end of your prefix. The prefix will be added to the reused items.
Lastly, you have the option to add a relationship from the reused item to the original.
After you have configured what Item Types you want to reuse, you can configure which fields and widgets you would like to be included. Under
Fields to Copy, select the
Configure button.
This will open the
Requirement Field Options window. Under the
Fields tab, you can either have all fields of the Item Type included in the reuse, or select individual fields. If you do not select a field to be included in the reuse rule, it will be blank in the new item.
You can also select which
Widgets you would like to be included in the reuse. Similar to the
Item Fields,
Widgets that are not included in the reuse rule will be empty in the new item.
After you have configured what fields and widgets to copy, save the rule. The rule will now appear under the
Reuse Options. The option to
Only show applicable means it will only show rules that are possible with the component, set, folder or item you have selected to Reuse. From here, you can also edit the rule, or delete it if it is no longer needed.
#requirementsmanagement #administration
