Oh no! and Oops! Common server error messages in Jama
By Jason posted 07-28-2016 12:18
"Oh no!" and "Oops!" are two common server error messages you may encounter while using Jama.
Oh no! There was an error with your request.
This error message is shown when a server error occurs. Select the Show Technical Details link for more information. Common errors in the technical details include:
    • org.springframework.transaction.CannotCreateTransactionException:
          Could not open Hibernate Session for transaction; nested exception is org.hibernate.exception.GenericJDBCException: Cannot open connection
      The Jama server is unable to connect to the database. Possibly the password for the database user has expired or the database server is down. The contour-c3p0.log file may have more information.
    • java.io.FileNotFoundException: /home/contour_home/database.properties (Permission denied)
      The Jama server was not able to create the database.properties file during installation due to file permissions in the contour_home folder.
      com.jamasoftware.contour.view.controller.file.FileDownloadController.handleRequestInternal(FileDownloadController.java:99)
      When downloading an attachment, Jama was not able to open the file where the attachment is stored. This can be due to file permissions on the server or an invalid path in the file name.
If you are not able to resolve the error, open a support ticket with the entire contents of the Show Technical Details text box and a recent Support Bundle (or contour.log and contour-c3p0.log files, for versions of Jama before 8.0).
Oh no! Sorry, we cannot find that file in our system.
This error usually means that the application server does not have a URL configured to handle the given URL (rather than a document that can not be found in Jama, for example). There are three common causes:
    • Exporting a Filter with a semicolon in the name
    • Accessing Jama's API with the wrong URL (for example, http://servername.example.com/contour/api-docs instead of http://servername.example.com/api-docs/)
Oops! It appears that you aren't authorized to view these files.
This error message is returned if a user tries to view an attachment or report that is in a project they do not have access to. There are three common causes:
    • Opening a report from a bookmark or link without logging in to Jama first
    • Attempting to view or download an attachment that does not exist in Jama
  • Opening a report with a character in the name that is not valid in a filename. (For example, "/" or ":")
If you are not able to resolve the error, open a support ticket and attach a recent Support Bundle (or contour.log and contour-c3p0.log files, for versions of Jama before 8.0).
#installation
