As noted previously, the Status is a unique calculated field. You won't be able to add another value in this Status Pick List because it is tied directly to the functionality of the Test Center. As a workaround, we recommend adding a custom field or Pick List to the Item Type. Just note that, if you add a custom field to the Test Case Item Type, it will not be inherited by the Test Run.
