The parameters Jama automatically sends to BIRT reports
By Kristina posted 01-30-2015 22:31
Jama sends BIRT report several built-in parameters which do not need to be set up when adding the custom report to Jama. The following will be automatically sent to the report:
Parameter                                               Data Type                        Returns
report_projectId                                       String                                projectId (looks like an integer)
report_organizationId                             Integer                              organizationId
report_format                                           String                               html, doc, xls, pdf
report_userId                                           Integer                              userId
report_baseUrl                                         String                                Jama base url
report_name                                             String                                File name
To add one of these parameters to your custom BIRT report, add the parameter in the same way you normally would. When adding this report to Jama, do not add these parameters to the
report Criteria section. Jama automatically sends these parameters to
the report.
[Originally posted by Shawnna Williams]
#BIRT
