How to Decide: Which Jama Reporting Tool To Use
By Shawnna Williams posted 03-25-2020 10:11
Jama Reporting Tools
Jama comes with several tools to export your data:
  1. Word and Excel Exports and Office Templates
  2. Velocity Reporting
  3. BIRT Reporting
Lets take a closer look at our Word and Excel Exports and mail-merge based Office Templates option. These tools are great for quickly getting information out of Jama Software simply but, sometimes the built-in Word and Excel Exports and Office Templates don’t quite give you what you want without post-processing. Exports and Office Templates can export your data into a formatted “document” (with headers, footers, a table of contents, cover page and heading levels) but, they are limited when you need to customize the following:
Ordering of documents
Word templates will always order the included items in the same order that they appeared in Jama Software when the export was generated. If you’d like to make sure like items stay together or certain item types always display before others, you’ll need to use a custom export.
Style Formatting
Though we have support for basic text formatting like bullets and text decoration, Word templates do not support control for page formatting options like section breaks or custom page numbering. Neither BIRT nor Velocity provide analogues for every option available to native Word documents, they’ll provide a broader level of control than Word exports do.
Ancestors and descendants
Word templates have limited support for children, but BIRT and Velocity both allow much more access to follow relationships and tree structure through multiple levels.
Conditional logic
BIRT and Velocity both allow much more control over when and where to display information than Word does. If you’d like to display an item’s status, but only if it was created more than 30 days ago and has an upstream relationship to a Feature, you’ll need to use an advanced reporting engine.
Sourced from Community article: Introduction to Advanced Reporting
Alright, so what if you find that you do need to add: some logic, custom formatting, grouping of like items, access to child-items? You know that you have special considerations that require more control over the report output than Word templates are able to provideNote: if you can use the simpler option, we highly recommend it!
Custom reporting will be the best way to get your data the way you want itLuckily, Jama also includes the ability to upload reports created using Velocity and BIRT. But now we are faced with this next question: which tool should you use?
To help in this decision, take a quick look at this chart showing comparison across Velocity, BIRT and Office Templates (also available on page 4 in Advanced Custom Report How To Guide).
Jama Reporting Tools Comparison Chart
Velocity
BIRT
Office Templates
Output to Word
X
X
X
Output to Word using Word's Styles
X
X
Output to Excel
X
X
X
Output to HTML
X
X
Output to PDF
X
X
Possible to run report based on data results viewed in Jama (current view)
X
X
Ability to generate charts and graphs
X
Apply programmatic logic and use parameters
X
X
Ability to re-import in Jama and update existing items
X
Access to Jama's API
X
Ability to run SQL queries for data
X
Embed images into document
X
X
X
When considering Velocity Advanced Reporting:
Velocity is a Java-based language that comes with the web server Jama is installed with. It calls the Jama Velocity API (not the Jama REST API) and exports the data as HTML.
When to Use Velocity for your report
  • When your final report needs to be a “document” (export with headers, footers, heading levels, Table of Contents, etc.)
  • Relationships  – usually with logic applied to them
Example: Only show Subsystem Requirements downstream from this System Requirement.
  • You need to show more than one item type in a single table
Example: One row shows the Requirement fields as well as it’s Verification status.
  • When logic has to be applied to the data in the report
Example: Only show items with a certain Status.
Example: If a Test Case Status is Passed, make that cell or text green. If it has Failed, make the cell or text red.
  • Context-based reports – The user pre-selects the data to send to the report from a Component, Set, Folder, Filter, Baseline, etc. This makes the report very flexible.
What skills do you need to create custom Velocity reports:
  • You are comfortable writing software scripts
  • You will have to navigate a template-tag systemintegrated directly into Jama Software’s internal Velocity API, to integrate through sets of items then evaluate each item to define how it will be handled.
  • You prefer a simple, text-based interface
  • No special software to download, the Velocity tags are in the HTML
  • You can do your editing in whichever Text Editor you choose.
  • Syntax similar to other embeddable scripting languages so, this method would work best with users who have experience writing scripts (as per above).
  • You’d like to run your report on user-specified sets of items
  • You have the option to run Velocity reports as “context-sensitive” and can run these reports against only the item or group of items the user is viewing when the report is generated. Opens up the functionality of running reports against a wide range of projects, item types and other variables.
  • You’d like your report to iterate over sets of items and apply conditional logic
  • Velocity allows you specify multiple control flows using conditional statements and loops.
Community Velocity reports
Community reports are reports that are free for customers but, are as-is and can be found here: https://github.com/JamaSoftware/Community-Reports. Customers can download the report(s) and install them on their own self-hosted instance or request that a report is uploaded to their hosted instance by contacting Customer Care.
  • Upstream Traceability
  • Test Results Report – Grouped by Test Case
  • Test Results Report – Grouped by Test Cycle
  • Review Center Stats Report
  • Sync Status Report
When considering BIRT Reporting:
BIRT is a freeware tool with a WYSIWYG interface, allowing you to directly query the Jama database using SQL queries.
When to Use BIRT for your report:
  • The report will be displaying charts and graphs
  • Dashboards/Analysis (sometimes) – If the analysis requires the report to get more than one level of relationships, Velocity would be a better choice.
  • If there aren’t appropriate API calls (Velocity API)
Example: The report needs to show comments from a review.
Example: The report shows how many people logged on to Jama in a given day.
  • Rollup/grouping tables (sometimes)
What skills do you need to create custom BIRT reports:
  • You are comfortable writing SQL queries
  • Be familiar with Jama Software’s database schema
  • Fluent in SQL to know how to select statement to join multiple tables while filtering out the data you need.
  • You prefer a GUI interface
  • You will need to install and learn the capabilities of the separate BIRT editor, this will require the dedicated time of an independent learning personality.
  • You’d like your report to contain visual representations of data
  • BIRT’s editor is great for visual learners; allowing you to build your report by adding and arranging components on a page, built-in tools render charts, graphs and tables wit h ease.
Community BIRT report
s
  • Review Center Comments Report
  • Visual Utilization Report
  • Utilization by Project
Developing your own custom reports:
On Premises and Self-Hosted Customers: Customers with On Premises or Self-Hosted instances of Jama can develop their own reports and upload to their sites as needed.
Hosted Customers: If your instance is hosted by Jama, you will need to purchase an On Premises sandbox for development. Once your report is ready to move into production, Jama’s Customer Care team can upload it for you.
Instructional videos can be found here under Advanced Reporting: https://community.jamasoftware.com/education and Jama Consulting Services can also be engaged for training that is tailored to specific reports.
Contact your Account Manager if you would like more information on training or an on premises sandbox.
Jama Report Development:
If your team does not have the resources or the time to develop your own report, Jama Consulting Services can develop the report for you. Contact your Account Manager for more information about these services.
#velocity
#ReportsandDashboards
#ImportandExport
1 comment
Creating word with BIRT might be a brave attempt for large documents.
