If you want to do a fresh install of Jama 8.x or you are upgrading from an older version of Jama, this is your quick guide to get installation started with Jama 8.x. First things first, make sure you are fully aware of the Supported Software. Jama 8.x runs on Linux only, which means Windows is no longer supported. We support MySQL and SQL Server only; if you are currently running Jama on Oracle you need to migrate to one of the two databases that are supported. If you are doing a fresh install of Jama 8:Pre-requisites:
Follow the steps below:
If you are upgrading to Jama 8:The instructions to upgrade to Jama 8 may vary depending on the environments (OS and database) that Jama is currently running on. Check the table below to find which one of the setups matches yours. Follow the instructions provided below for your specific setup. Pre-requisites for all setups:
1: Oracle + Windows
2: Oracle + Linux
3: MySQL or SQL Server + Windows
4: MySQL or SQL Server + Linux
© Jama Software HEADQUARTERS|135 SW Taylor Suite 200, Portland, Oregon, 97204
