Generate review comments report for a filter
  • 1.  Generate review comments report for a filter
    Posted 06-19-2018 01:03
    Hi All,
    My requirement is,
    • In the project I create a filter and add few test cases to it.
    • In the review center I select this filter to create a new review and inturn send it for review.
    • Then, I will go to my filters tab and try to generate the word report using office template option.
    • I need to create a report with all the review comments created for these test cases inside this filter.
    • I do not want to use the default reports like "Review Center Comments" or "Review Center Stats Report", where we select the review and generate the report.
    • The filter should be used as the input for this report.
    • I would like to create this report using velocity template.
    Please help me on this.
    Also, please let me know how to fetch a filter details, and if there is any relationship between filter and review (if the filter is selected to create a new review).
    Also, please let me know if we have any REST API to achieve the same.
    Sathish Babu
  • 2.  RE: Generate review comments report for a filter
    Posted 06-19-2018 08:19
    I have created a velocity report some time ago, that might do what you need.
    I have posted that here: Best Practices - Jama Software Community
    Jamasoftware remove preview
    Hidden page that shows all messages in a thread
    View this on Jamasoftware >
    Harald Hotz-Behofsits
    Frequentis AG
  • 3.  RE: Generate review comments report for a filter
    Posted 06-21-2018 10:23
    Hi Sathish,
    Can you say more about what information you want to gather that is not present in the community reports, and why you do not want to use them?
    We unfortunately do not have endpoints for the Review Center in our REST API. We are very curious to know what kind of information you would want to get from an API that the Review Center Comments Report and the Review Center Stats Report do not contain.
    Sara Jensen
    Developer Support Engineer
  • 4.  RE: Generate review comments report for a filter
    Posted 06-26-2018 23:20
    Hi Sara,
    My intention is to get all the review comments using filter id. But in Review Center Comments Report and the Review Center Stats Report, i need to select the review from dropdown.
    I dont want to select any review from dropdown. If i parse filter id, then i will pull the review comments added for the document added in the filter.
    In Review Center Stats Report, some of the expected fields are not there.
    Ex: Comment Status, Comment ID, Comment Creation date, etc.,
    For this purpose only, i am trying to pull all those details using Rest API.
    Sathish Babu
