How to display the test case steps and relationships in a contour review?
  Thread closed by the administrator, not accepting new replies.
  • 1.  How to display the test case steps and relationships in a contour review?
    Posted 03-09-2015 19:17
    No replies, thread closed.
    As part of a review, I would like to review and comment on the test steps. Is this possible?
  • 2.  Re: How to display the test case steps and relationships in a contour review?
    Posted 03-09-2015 19:43
    This is quite a question to unpack, Tony! ;) First, it is possible to display the test steps in the review center—here's a post that walks you through it.
    Second, there is not a great way to display the relationships in a review—you can create a custom field in your Test Case and manually add the related requirements, but that is static so it is not ideal. There's an Idea posted in the community that you can add feedback to if you'd like to see that as an option.
    Lastly, it is not possible to provide review comments on test steps directly; you can select them, but the Add Highlight dialog box will not pop up.
    You can respond if you have further questions about this particular capability.
