Project used as a library
  • 1.  Project used as a library
    Posted 10-11-2016 17:21
    Does it make sense to make a project to be used as a dedicated library?  The contents of the library will then be reused across multiple projects.  OR should each project have it's own library?
  • 2.  Re: Project used as a library
    Posted 10-11-2016 18:15
    Hi Melmer,
    Using one project as a library is a common case for the Reuse feature. We go in-depth on the library scenario in an "Ask Jama" webinar; I'd recommend watching that: https://community.jamasoftware.com/jama/topics/ask-jama-reuse-wrap-up-including-answers-to-your-unan...
  • 3.  RE: Re: Project used as a library
    Posted 26 days ago
    Do you know if there is an updated link?  The one above did not get me there.
    Kirk
    Kirk Wilkins
    Church of Jesus Christ of Latter Day Saints
    SLC UT
  • 4.  RE: Re: Project used as a library
    Posted 26 days ago
    Hi Kirk!
    If you want to learn more about Reuse & Sync we have a section for it under Education in the Community: Reuse & Sync
    I would recommend the Creating a Library and Ask Jama videos.
  • 5.  Re: Project used as a library
    Posted 10-11-2016 18:36
    Thanks Kristina King
