It cannot be removed.
Sent: 01-13-2017 01:50
Subject: Re: How to use Relationship Status?
Follow up question. Is it safe to remove Relationship status from Pick Lists? Will it somehow affect Jama functionality?
Thank you for your answer
Vlada
Vlada
Sent: 01-05-2017 13:35
when there is some functionality people definitely invent how to use it even it does not make sense...
HA. That is so definitely true. But as far as removing it goes, there's nothing planned. The conversation was essentially, "yes, that feature needs to be improved or killed," but both of those are incredibly low priorities.
Sent: 01-05-2017 02:32
I agree. Do you plan to remove this functionality in the future? You know, when there is some functionality people definitely invent how to use it even it does not make sense...
Vlada
Sent: 01-04-2017 18:48
Hey Vlada,
Thanks for checking in on that. This particular Status field doesn't have much for functionality; because it's not a field, it's not visible in filters or reviews.
Sent: 01-04-2017 02:04
The second case is correct. The team was speaking about Status as showed in the attached picture.
Thank you
Vlada
Sent: 10-05-2016 17:01
Vlada, there are two different Status indicators for relationships. The first does pertain to the rules, in that the item would be out of compliance with the rules and have an orphan, be missing downstream, etc. Carmen posted an article">https://community.jamasoftware.com/jama/topics/functionality-of-the-relationships-status-indicator">article detailing this use. There is also the Status">http://help.jamasoftware.com/relationshipsettings.htm">Status available on the Relationships widget. I honestly haven't heard of folks using this one, so I doubt this is the one your user is referring to...
However, it would be helpful to find out for sure which Status the user is referring to. I imagine it is the relationship status; it'd be helpful to know if the user is concerned with suspect or orphan items, in terms of filtering.
