user group permissions jama 8.x
  • 1.  user group permissions jama 8.x
    Posted 07-28-2016 14:37
    Per jama documentation in the user guide section migrating existing data.
    ** replace 91:91 with your server's corresponding user:group
    When installing jama there is no account we use except our own personal account or root to perform the install. With Jama running in docker containers is there a user:group we should be using or is there a local account we should be setting up with access to these folders on the CentOS box?
    This statement is a bit unclear with the install process of Jama using docker now.
  • 2.  Re: user group permissions jama 8.x
    Posted 07-28-2016 16:27
    Hey Nick,
    It sounds like we might need to clarify the user guide. From my understanding, if they installed Jama as root, the the files in /data/contour should also be owned by root. Does that answer the question?
  • 3.  Re: user group permissions jama 8.x
    Posted 07-28-2016 17:12
    Yes, but what is the recommended practice then. Should jama be installed under a generic account with sudo rights and not as an individual user then or root is acceptable in this new model?
  • 4.  Re: user group permissions jama 8.x
    Posted 07-29-2016 19:10
    Hi Nick,
    At this time, our recommendation is to install and run Jama as the root user. We do not recommend installing Jama as a different user. Our user guide unfortunately is misleading and inaccurate.
    The permissions for the /data folder actually must be configured with permissions for the user and group 91:91. This is because jamacore runs as a tomcat user with a pre-defined user ID 91.
    Thank you for pointing this out and generating a discussion. I will be updating our guide so that this information is correct and clear.
    Iris
