Hi Brenda,
This is a defect, SOS-DEF-633; no matter what you do from this view, the "facet"
filtering does not affect the export.
The workaround would be to create an
advanced filter that mimics this faceted view, and export from the filter results.
Sent: 07-13-2017 16:22
Subject: Default Excel Export
I'm trying to do a simple export using the default Excel option but I'm not getting exactly what I want. Can you let me know if it's even possible? I select a set or component, view in List View, then Filter Items by some criteria say, show only items of type system requirement and not any folders. When I export, I get everything in that set/component (folders and system requirements) instead of the filter results in the reading pane. Is this per design? Is there a simple way to export just what I have selected in the reading pane?
Brenda McCourt
General Atomics Aeronautical
