On our Jama items, we use a Roll-Up fields to show the % of "A" values downstream.
But we find differences between:
- The value shown in our upstream item.
- The export value of this upstream item.
- What we really have in downstream items.
#1st case:
An item display "100% of "A" downstream" > Export "100% of "A" downstream" > Reality: 1 item is "A", a second one is "B" = 50%.
Here you can see that JAMA doesn't reflect reality.
#2nd case:
An item display "100% of "A" downstream" > Export "0% of "A" downstream" > Reality: 0 item with "A" downstream.
Here the roll-up displayed in the item just doesn't reflect the reality but the export does.
How can I fix this issue ?
I have already tried to re-index the project but nothing change.
Is it because our items are locked ? I'm not sure because this field should be updated even if items are locked, no ?
Mathieu
