Project doesn`t alloy Project Key change
  • 1.  Project doesn`t alloy Project Key change
    Posted 19 days ago
      |   view attached
    ​​Why JAMA doesn`t allow me to change Project Key, even there is no same Key used in any other project?
    I have checked multiple times, at there is no same named Key used.​
  • 2.  RE: Project doesn`t alloy Project Key change
    Posted 19 days ago
    Edited by Anna Henke 19 days ago
    Juho, there may be  a deleted project within Jama that use the key you want to change to.
    Jama did not delete projects entirely in the past, but only set them inactive, resulting in not being able to reuse the item key. You are able to hard-delee projects nowadays.
    You may also want to check if such an archived project exists.
    Depending on you level of access you could also check in the Permissions section of the administration if the project exists (the second one you blacked in the screenshot) and you may just not have the permissions to view it.
    Last option would be to query the database and check what is going on.
    Good luck
    Anna Henke
