Does the root password reset when upgrading?
  • 1.  Does the root password reset when upgrading?
    Posted 05-26-2017 04:51
    Hi!
    Older version of Jama. We're upgrading from 4.2.7 to 2015_2. Will the root password be reset once the upgrade is complete? If not, what are the ways to recover it?
    James
    James Krych
    GRSi
    SC
  • 2.  RE: Does the root password reset when upgrading?
    Posted 05-26-2017 11:37
    James, this value is stored in the database, so it should not reset when you upgrade (because I assume you're keeping the same data!). You can reset this with a database query. To reset the Jama root user password to 'password':
    update userbase set password='2d8ccb9f3d83be83c0db0ff2c3ee24b7' where userName='root';
