Release Drop Down List across Multiple Projects
  • 1.  Release Drop Down List across Multiple Projects
    Posted 06-07-2018 07:57
    I have multiple Projects in JAMA, and some of these Projects (components) are part of the bigger platform.  Each Project/MicroService will have their own Version number, so each component/project has their own release number but they are part of a larger platform release (Marketing Released Version).
    I want to know what work items are in each component/project, so I need a drop down list that I can select on the work item(s) that is common across each component.
    I cannot use Release Number as these are only available on each project
    I cannot use Tags as Tags are not shared across projects
    I don't want to create a new field (item type) as some components/projects in my solution are not part of the bigger platform.
    Has anybody got any suggestions for solving this?
    Andrew Knight
    Tunstall
  • 2.  RE: Release Drop Down List across Multiple Projects
    Posted 06-12-2018 16:23
    Hi Andrew,
    I believe you might be able to accomplish the task at hand by creating an Advanced filter. Please consult the resources below for more information.
    Advanced filters
    Leveraging Filters - Jama Software Community
    Getro Naissance
