Each paragraph is formatted as a heading when I export from Jama to Word using a Mail Merge template
  • 1.  Each paragraph is formatted as a heading when I export from Jama to Word using a Mail Merge template
    Posted 08-08-2018 00:35
    I am currently attempting to work through a bug I am experiencing when I export from Jama into Word using a basic Mail Merge template. When I use the code below, I find that each paragraph and space in the document (even if not a heading) is formatted as a heading, meaning that it appears in my Navigation Pane. Since we rely heavily on the Navigation Pane to navigate through documents, this ends up being quite messy.
    • «TemplateStart:DEFAULTTEMPLATE»
    • «TemplateStart:FLD»
    • «TableStart:HEADING»«name»«TableEnd:HEADING»
    • «description»
    • «TemplateEnd:FLD»
    • «TemplateStart:TXT»
    • «description»
    • «TemplateEnd:TXT»
    Is there any way to format either the source code within Jama or to change the Mail Merge code to prevent this from happening?
    Anja S
  • 2.  RE: Each paragraph is formatted as a heading when I export from Jama to Word using a Mail Merge template
    Posted 08-08-2018 17:33
    Hello Anja,
    Does this mail merge code work better for what you are trying to do?
    «TemplateStart:FLD»
    «documentKey»
    «description»
    «TemplateEnd:FLD»
    «TemplateStart:TXT»
    «documentKey»
    «description»
    «TemplateEnd:TXT»
    «TemplateEnd:DEFAULTTEMPLATE»
    Dana Medhaug
    Technical Support Engineer
