Lookup Type List
  • 1.  Lookup Type List
    Posted 06-29-2020 02:24
    before update to new Velocity I was using HibLookupTypeDaoImpl::getLookupTypeList(int scope, int refId) function to get all Pick Lists defined across organization. I tried to get the same by calling $documentSource.getLookupTypeList(int scope, int refId) but it seems not to have this function. Does anybody know how to retrieve same info now?
    Thank you for any advice.
    Kind regards,
    Roman
    Roman Sickaruk
    ON Semiconductor
    roman.sickaruk@onsemi.com
  • 2.  RE: Lookup Type List
    Posted 06-30-2020 07:36
    Hi Roman:
    I would try $documentSource.getLookupList(int type)
  • 3.  RE: Lookup Type List
    Posted 06-30-2020 07:49
    Hello @Chloe,
    Thank you for your advice.
    I ended up using this exact function.
    I get the Item Type Map for the Organization, iterate over item types and fields looking for Lookup or Multi fields and retrieving the int type parameter as LookupId.
    This way I get all used Lookups (Pick Lists)​. However, with function mentioned in post root I was able to retrieve all (even unused) Lookups. Is there a way to achieve same result, please?
    Thank you again.
    Kind regards,
    Roman
    Roman Sickaruk
    ON Semiconductor
  • 4.  RE: Lookup Type List
    Posted 06-30-2020 13:21
    Roman:
    Hmm, I don't seem to have a direct answer for this. There seems to be about three calls that have to do with lookups in the $documentSource, I wonder if there is something there to be used?
