Date field issue
  • 1.  Date field issue
    Posted 11-29-2018 07:53
    ​Dear Jama team,
    I noticed an issue with the datefield that behave incorectly:
    - When a date with a day greater that 30 is selected when editing the item in a Jama center panel, the date entered is inconsistent or not taken in account.
    - When I use the edit button that opens the item in a new windows, the date can be entered and saved correctly.
    I guess there is a difference between the 2 views how Jama is handle the date. For information I use the DD/MM/YYY on my computer.
    Do you have a way to fix this issue?
    Best regards.
    Fabrice
  • 2.  RE: Date field issue
    Posted 11-30-2018 13:35
    Fabrice:
    Hello, I have a few questions. Could you please elaborate on which view you are editing in? I think you are talking about editing in the List View or perhaps the Single Item View but, I could use some more clarification. Would there be a way for you to attach some screenshots to point me in the right direction? Also, I am curious as to which date/time field you are referring to: is it Created Date, Modified Date, Last Activity Date or just one of the generic "date" fields?
    Looking forward to hearing back.
  • 3.  RE: Date field issue
    Posted 12-01-2018 02:09
    Hello Cloe,
    I will add some screenshots to detail the issue on a generic date field for a customized item, not created date neither modified date.
    ​The version I'm using is Build date: 2018/11/02 09:55 - Version: Jama Connect 8.32.0
    In the single item view, opened when I click on the pencil to edit a date field and select a date. The date is correctly displayed on the field for example 28/12/2018. But when you leave the field, the date is not reccord(for day >12) or incorrectly reccord (forday <=12). It seems that the day and month are swapped.
    In the editing window, opened when I click edit buttom from the list view or single view item. The date is correctly display and set from the datepicker.
    For information, I also noticed that when their is also the same kind of issue with the richtext steps that appear with formatted with the richtext toolbar when editing in single view item and is only a textbox when editing in the sperated window:
    single item view, steps is a richtext field
    editing window, steps is not a richtext field
    Thank you.
    Best regards
    Fabrice
  • 4.  RE: Date field issue
    Posted 12-10-2018 11:50
    Edited by Chloe Elliott 12-10-2018 12:03
    Fabrice:
    Thank you for your patience, yes this is a known issue with the EU time/date: when you do an inline edit the wrong date is saved. The workaround is what you have already figured out: use the edit button instead. For your reference, the defect key is: SOS-DEF-765, this post and your org is related to this defect. You can check the Release notes for this key to see when it gets fixed.
    As for the rich text issue with editing the Test Step, in the first picture you are editing the Template of the Test Case, so this is allowing you to use the Rich Text editor to configure how you want the test steps to look like to the testers.
    Here you are editing the Test Case, not the Test Case Template so it allows a different level of editing.
    I hope this helps!
  • 5.  RE: Date field issue
    Posted 10-02-2019 05:28
    I'm facing the same kind of issue regarding US (MM/DD/YYYY) / EU(DD/MM/YYYY) date format with the new review center configuration tab. When I enter a date from the date picker (October 7th)  it is converted in the wrong date (10th July).
    It seems it is the same issue as mentioned previously,  there any progress on this issue SOS-DEF-765 ?
    Thank you
    Best regards
    Fabrice.
    Fabrice
  • 6.  RE: Date field issue
    Posted 10-02-2019 09:22
    Hi Fabrice
    From what I dug up, it looks like this is a defect our production team is currently and actively working on for future release.
    Regards
    Godiva Hunt
  • 7.  RE: Date field issue
    Posted 10-31-2019 01:06
    The issue regarding the date SOS-DEF-4436 was corrected on the new release 8.43.
    However the SOS-DEF-765 that was previously described still exists, do you have a planning for its resolution ?
    Even with the workaround, it still annoying for our team because it is not consistent in all views and leads to false date entries.
    Thank you.
    Best regards
    Fabrice.
    Fabrice
  • 8.  RE: Date field issue
    Posted 10-31-2019 10:37
    Hi Fabrice
    Thanks for checking in! I just spoke with our analysts and they said SOS-DEF-765 is filed as Build (in the process of being built) and is scheduled to be fixed in Jama's 8.44 release.
    Godiva Hunt
