get multi-select items as list in velocity
  • 1.  get multi-select items as list in velocity
    Posted 12-20-2019 11:20
    Is there any way to get the selections of a multi-select field in a velocity report as a list of strings? Currently when you use the $velocityReportUtil.getValueForField function you get back a single string with commas between the selections. This is problematic, however, since the picklist items themselves may have commas, so you cannot simply split on "," to get a list of the selected items.
    The testCaseSteps field has a similar issue/behavior when using getValueForField, but since it is a built-in special structure, you can also access it from the document object ($doc.testCaseSteps), and subsequently iterate over its line items (and separately access action / expectedResult / notes fields). There doesn't appear to be a similar way to access multi-select information, but the velocity documentation is so limited it may just be hard to find.
    -Rafael
    Rafael Medina
    ON Semiconductor
  • 2.  RE: get multi-select items as list in velocity
    Posted 12-27-2019 07:08
    Rafael:
    Hi, hope you are having a wonderful holiday season! So there are a few things here to consider, all of which are manual in nature and yes, are not officially in the documentation. Just some possible workarounds to try.
    One, try not to use 'commas' in picklist items in general.
    Two, If you need to, use a "low accent delimiter" (ˏ) instead of a comma in Picklist items. Use something like U+02CF - "ˏ" which looks just like a comma but isn't.
    Or three, you could look over the items before you export and manually change anything that has a comma in it.
  • 3.  RE: get multi-select items as list in velocity
    Posted 01-02-2020 10:34
    Happy Holidays!
    Can we file a bug ticket to address the information loss here?
    In the meantime I can try to work around the issue, but we currently have around 200 picklists, so ensuring none of them use any commas in any of their options is not really a robust / sustainable solution. (I'm not aware of any of our picklist options that require commas, but there is no way to enforce the limitation, which can lead to silent errors -- the worst kind)
    -Rafael
    Rafael Medina
    ON Semiconductor
  • 4.  RE: get multi-select items as list in velocity
    Posted 07-03-2020 02:59
    Hello @Chloe,
    we seem to find a solution to this with Rafael. I am enclosing code snippet in case anyone will face similar request.​
    #foreach($doc in $documentList)
        #foreach($field in $documentSource.getItem​($doc.document.getId()).getCustomFields())
              #if($field.getFieldName() == "multiselect")
                 #foreach($value in $field.getFieldValues() )
                       $documentSource.getLookup($mathTool.toInteger($value)).getDataValue() <br/>
                 #end
              #end
        #end
    #end
    This will iterate over items and their fields and search for field with key "multiselect". For that it will get currently set data values as a a list and in case of Lookup (Pick List) those are of Lookup type.
    Kind regards,
    Roman
    Roman Sickaruk
    ON Semiconductor
    roman.sickaruk@onsemi.com
  • 5.  RE: get multi-select items as list in velocity
    Posted 07-06-2020 07:55
    Roman and Rafael!
    Thank you for collaborating and then coming back to the Community to share your hard earned Velocity code solution!
    Both of you have earned the Solver badge, look in your profiles to see:
