Relationship rules and the Re-use functionality
  • 1.  Relationship rules and the Re-use functionality
    Posted 05-16-2017 05:34
    Hello Jama,
    We are currently at v8.4.1 and wanted to understand how we could make the relationship rules apply while re-using an item.
    As of now, when we Reuse items, we select the option to 'Add a relationship from the original item'. This feature helps us track items easily, however, it does not use the Relationship rules that were applied for the item type in the project.
    Is there a way we can have Jama apply the relationship rules when adding a relationship to the original items during a re-use?
    Please advise.
    Thank you!
    Vishal R
  • 2.  RE: Relationship rules and the Re-use functionality
    Posted 05-16-2017 11:39
    Hi Vishal,
    There is not a way to enforce the rules in this case. I am trying to determine if that is a bug or if it was a known caveat that was released with Relationship Rules. I'll let you know what I find, although unfortunately it won't help you enforce the rules.
  • 3.  RE: Relationship rules and the Re-use functionality
    Posted 05-17-2017 03:27
    Thank you Kristina!!
    Please keep me posted.
    Good day.
    Vishal R
  • 4.  RE: Relationship rules and the Re-use functionality
    Posted 05-22-2017 16:00
    Hi Vishal,
    The answer to the question of "why doesn't Reuse conform to relationship rules" is that it wasn't designed with that in scope, however, it's not being considered a bug (because the relationship rule functionality was released with a relatively small scope, with plans to update its functionality). This means we're tracking it as a story for consideration next time we work on that functionality. I'm sorry there isn't something we can do for you now to make it conform.
  • 5.  RE: Relationship rules and the Re-use functionality
    Posted 05-25-2017 07:28
    Thank you Kristina!
    Looking forward to its implementation.
    Vishal R
