How to update Selenium Automation(JAVA) Test Result on Jama using Rest API
  • 1.  How to update Selenium Automation(JAVA) Test Result on Jama using Rest API
    Posted 06-03-2020 09:07
    How to update test result for test cases in any Test Cycle using REST API?
    I want to integrate Selenium Webdriver Java based Automtion framework with Jama using Rest API, when am running any test case simultaneously want to update result of test on test case on JAMA in test cycle.
    Madhur Agrawal
    GSPANN Technologies
    Noida NC
    +91 9789092124
  • 2.  RE: How to update Selenium Automation(JAVA) Test Result on Jama using Rest API
    Posted 06-03-2020 12:20
    Hi Madhur:
    Have you seen our API Cookbook? It might be a good place to start, here is a link directly to the "Executing Tests through the REST API" section. There is also a section on Creating Test Cases and Test Steps with the API.
    Hope this helps,
  • 3.  RE: How to update Selenium Automation(JAVA) Test Result on Jama using Rest API
    Posted 06-03-2020 14:14
    Thanks for the support :)
    Madhur Agrawal
    GSPANN Technologies
    Noida NC
    +91 9789092124
