  • 1.  Reviews are empty
    Posted 01-24-2022 05:31
    Since today, all new reviews are empty when we open them in the review center (i.e. message "no items match the current filter" although no filter is selected".
    We haven't had a server of software update this weekend so we don't understand why the reviews are empty. Existing - still open - reviews are okay, so the problem only persist for new reviews or reviews where we did a 'update new revision'.
    Can you please help ASAP?
    PS: We did have the same problem when we updated to a new Jama version last year, but we didn't update anything recently.
    We are using Jama on premise Build date: 2021/07/16 10:31
    Fred Roseboom
    VSE
    Veenendaal
  • 2.  RE: Reviews are empty
    Posted 01-24-2022 09:12
    Edited by Carly Rossi 01-24-2022 09:11
    Hi Fred,
    I can absolutely understand the concern, especially given this affecting new reviews. Partnering with Support would be the best way to dig deeper into this to determine the root cause (and resolution) -- please a ticket here.
    Carly Rossi // she/her
    Portland, OR
  • 3.  RE: Reviews are empty
    Posted 11-16-2022 05:27
    Edited by Sandra Wiegratz 11-16-2022 05:28
    Hello
    We encountered the same issue today, did you manage it without updating your Jama version once more?
    Thank you
    Sandra Wiegratz
  • 4.  RE: Reviews are empty
    Posted 11-16-2022 05:50
    A full re-index solved our issue.
    Sandra Wiegratz
  • 5.  RE: Reviews are empty
    Posted 11-16-2022 05:53
    Hello Sandra,
    Last time we had this issue, downgrading to an older Docker version solved the issue.
    Met vriendelijke groet / Mit freundlichem Gruß / Kind regards,
    Fred Roseboom
    Project Manager
    T
    +31 (0) 318 54 57 44
    E
    froseboom@v-s-e.com
    VSE
    VSE
    V.S.E. Vehicle Systems Engineering B.V.
    Ravelijn 2, 3905 NV Veenendaal, The Netherlands
    T
    F
    +31 (0) 318 54 57 99
    E
    info@v-s-e.com
    W
    www.v-s-e.com
    Linkedin  youtube
    This electronic message transmission contains information from the company that may be proprietary, confidential and/or privileged. The information is intended only for the use of the individual(s) or entity named above. If you are not the intended recipient, be aware that any disclosure, copying or distribution or use of the contents of this information is prohibited. If you have received this electronic transmission in error, please notify the sender immediately by replying to the address listed in the "From:" field.
