Changing a Sub-item to Item
  • 1.  Changing a Sub-item to Item
    Posted 12-03-2019 10:13
    We have a number of sub-items that we need to increase a level to be stand-alone items. Is there a way to batch the sub-items to move them ?
    Elizabeth Rosenberg
    Alight Solutions
  • 2.  RE: Changing a Sub-item to Item
    Posted 12-03-2019 12:29
    Elizabeth:
    You should be able to go into the parent item and click on the "sub-item widget":
    Click this widget (which shows up when an item has sub/child items) and this window will pop up, where you can go to Actions > Convert to.
    Elizabeth, will this help you achieve your goals?
  • 3.  RE: Changing a Sub-item to Item
    Posted 12-03-2019 14:07
    unfortunately that does not work. because the sub-item type is the same as the parent item type, there is no conversion allowed.
    Elizabeth Rosenberg
    Alight Solutions
  • 4.  RE: Changing a Sub-item to Item
    Posted 12-03-2019 14:12
    Elizabeth:
    Yes, child items are like that. A little trick: try converting it to another item (anything but a text item, and something which allows you to keep most/all of the fields -you will have to play here) And then convert it again to the actual item you want.
