Filter on multiple instances of the same word
Jump to Best Answer
  • 1.  Filter on multiple instances of the same word
    Posted 03-16-2017 09:10
    Is it possible to search on multiple instances of the same word within the same field?
    In this example I've entered 2 SPRs and I'm attempting to filter on both of them.  Is that doable?
    words
    Melissa Gensure
    Pittsburgh PA
  • 2.  RE: Filter on multiple instances of the same word
    Best Answer
    Posted 03-16-2017 14:09
    I assume you want to find all items that have BOTH those numbers. You can create a filter to find key phrases in specific fields (using OR or AND in the criteria). Here is one I created based on your screenshot. The key is to use quotations around multi-word phrases so it finds that exact phrase.
    Test Runs
    Preston
