Error Reusing Items
  • 1.  Error Reusing Items
    Posted 21 days ago
      |   view attached
    I am reusing items from Project A into Project B with Upstream and downstream relationships, while syncing I am getting an error as follows:
    Error Reusing Items
    Invalid document location. Validation cannot be under Component.
    No changes were made.
    Please let me know if you need more info.
    Praveen Kumar
    Collins Aerospace
  • 2.  RE: Error Reusing Items
    Posted 20 days ago
    Hi Praveen,
    Thank you for sharing this. Based on your description and this error message, I believe you have encountered this defect:
    SOS-DEF-4419
    Reuse: "Invalid document location" error happens when attempting to reuse an item from one project to another if an item from the source project already exists with the same Global ID.
    Can you check both of your projects/items and verify if they share a Global ID
