Accessing attachments with no file
  • 1.  Accessing attachments with no file
    Posted 11-13-2019 00:05
    During some tests with Rest API, I've created attachments without a file assigned to them. I have now lost their IDs and they do not appear in the Attachments tab of the project (including when the 'Show All' checkbox is checked).
    Is there a way of retrieving/deleting those? They were definitely created because I received the ID back and could inspect them with GET methods (but as I said those previous IDs are now gone).
    Kamil
  • 2.  RE: Accessing attachments with no file
    Posted 03-10-2020 07:15
    Bumping this up as we still are looking for a solution.
    Also adding a question of whether mass-removal of attachments is possible (other than via Rest)? Currently removing unattached attachments requires clicking each one individually and selecting 'Delete' - not even CTRL/Shift selecting works in the UI.
    Kamil Cupial
    3Shape
  • 3.  RE: Accessing attachments with no file
    Posted 03-10-2020 10:18
    Hi Kamil:
    To find these attachments, try using the GET abstractitems endpoint:
    Fill in the created date field for the day they created the attachment items, and add the attachment item type (22 for attachments) to the item type field. This picture I posted is from using our REST documentation tool: Swaggar.
