Add dummy user accounts to Jama
  • 1.  Add dummy user accounts to Jama
    Posted 12-20-2018 12:41
    Hi Jama -
    We would like to add "dummy" user accounts to Jama to implement the workaround described in Skip Test Run. It appears that the only way to do that is to add a user that also exists in our Active Directory, which means we must add the "dummy" user to Active Directory as well. This has maintenance and security implications that we would like to avoid. Is there a way to add a local user to Jama, one that doesn't exist any where else in the organization's electronic tools?
    Theresa
    Fujifilm SonoSite
    WA United States
  • 2.  RE: Add dummy user accounts to Jama
    Posted 12-20-2018 14:18
    Theresa:
    Thank you for posting in the Community, I hope you are well. Unfortunately, you can only use one authentication method at a time. Therefore, you are correct, you will need to add the dummy user locally.
