Duration for test run
  • 1.  Duration for test run
    Posted 10-17-2018 16:16
    I am working at the organization of  adacel.jamacloud.com
    I am currently updating our scripts from soap to rest.  I am almost done but I do have a small problem.
    With soap, I was updating the testrun.duration with suds with a python.time object as follow :
    self.client.service.executeTestRun(self.auth, testRun.testRun.id,time, result,False,testRun.steps)
    time was something like this : 0:01:03 (1 minute 3 seconds)
    Now, I did not find the format of the duration that json needs.  The following is the payload :
            payload ={
                "fields": {
                    "actualResults":result,
                    "duration":??,
                    "testRunSteps":[
                            "status" : status
    I already tried integer such as 1, 2 or 3, but it gives incorrect result.  If I push 1, the duration shown on contour is 02:00:00, which doesn't make sense!
    So, what is the format need for duration?
    Thx a lot
    Pierre-Luc Boily
    Adacel
    Montreal QC
    5143941165
  • 2.  RE: Duration for test run
    Posted 10-18-2018 10:22
    Hi Pierre,
    Thanks for reaching out to us.
    For our API, the duration field is in milliseconds as an integer. So if you were to set the duration to be exactly 1 minute 3 seconds, you would have it be 63000.
    Justin Phang
    Developer Support Engineer
  • 3.  RE: Duration for test run
    Posted 10-18-2018 13:39
    Thx, it works!
    Pierre-Luc Boily
    Adacel
    Montreal QC
    5143941165
