Publish revision button unresponsive
  • 1.  Publish revision button unresponsive
    Posted 11-29-2019 11:39
    We have seen a few instances where the "Publish revision" button is unresponsive.  The user has worked through the Review Wizard and when getting to step 4 the click the button but nothing happens.  In one case, the user had moved an item out of the component that was included in the review.  In the other case, the user moved an item to another component and deleted one item.
    In both cases, the button was unresponsive and therefore they could not publish an updated review.
    Is there something specific we can do to avoid this situation?
    Michelle Anthony
    Sun Life Financial
  • 2.  RE: Publish revision button unresponsive
    Posted 12-02-2019 03:19
    Edited by Carmen Santos 12-02-2019 03:19
    Hi Michelle,
    In order to better understand the situation can you please confirm if the users were able to publish the review when going through the review wizard a second time, or after refreshing the page?
    Thank you!
    Carmen Santos
  • 3.  RE: Publish revision button unresponsive
    Posted 12-02-2019 05:37
    HI Carmen,
    They were not able to publish the review using the Wizard.  In one case, they had to just click "Publish" in order to be successful.  In the other case, I had to publish the review for them.
    ..Michelle
    ___________________________________________________________________________
  • 4.  RE: Publish revision button unresponsive
    Posted 12-03-2019 14:37
    Hi Michelle
    In order to investigate this issue properly, I'd like to recommend you submit a ticket. We may need to discuss sensitive information that we wouldn't want to share in a public setting. We'll be keeping an eye out for your support request.
    Thank you
    Godiva Hunt
  • 5.  RE: Publish revision button unresponsive
    Posted 02-17-2020 15:12
    Hi Michelle,
    We're having the same issue.  Did you ever submit a ticket and get a response on resolving this?
    Best regards,
    Calvin
    Calvin Kan
    Garrett Motion Inc.
    Torrance CA
    4245316591
  • 6.  RE: Publish revision button unresponsive
    Posted 02-18-2020 05:13
    Hi Calvin,
    Yes, i did submit a support ticket, but they were not able to resolve the issue.    We had been asked to provide  HAR file to help in troubleshooting, but we had already worked around the error and weren't able to provide one.   So far, the issue has not shown up again.
    ..Michelle
    Michelle Anthony
    Sun Life Financial
