REST API set field to pick list value
Jump to Best Answer
  • 1.  REST API set field to pick list value
    Posted 12-10-2019 14:08
    I'm using REST in C# to update several items at once. I want to set the value of some fields to a value from a pick list. How could I do this in C#?
    Jack
  • 2.  RE: REST API set field to pick list value
    Best Answer
    Posted 12-11-2019 13:52
    I've figured it out. Once you have the JObject item you want to edit and the int ID of the picklist option you want to set a field to, you can do something similar to below:
    public void updateItemPickList(long itemId, string field, int value)
        setLockState(true, itemId);
        JObject item = getItem(itemId);
        item["fields"][field] = value;
        try
            putItem(itemId, item);
            setLockState(false, itemId);
        catch (WebException)
    Jack
