Velocity Report showing reviews and comments
  • 1.  Velocity Report showing reviews and comments
    Posted 06-19-2018 11:17
    Attached is a velocity context sensitive report showing reviews, comments and related items.
    That report uses some stuff of the vodoo or jedi department, see below.
    #set($sessionFactory = $applicationContext.getBean("sessionFactory"))
    #set($session = $sessionFactory.getCurrentSession())
    #set($reviewsQuery = $session.createQuery("select rw from Review rw where rw.id in (select rev.review.id from Revision rev inner join rev.revisionItems ri where ri.version.originDocument.id in (select doc.id from Document doc where doc.globalId = :globalId))"))
    #set($revisionItemsQuery = $session.createQuery("select revision_item.id from Revision_Item as revision_item where revision_item.revision.id = :revisionId and revision_item.version.originDocument.id in (select doc.id from Document doc where doc.globalId =:globalId)"))
    with that approach it is possible to query anything that is not (yet) supported by api as needed.
    regards
    Harald
    Harald Hotz-Behofsits
    Frequentis AG
  • 2.  RE: Velocity Report showing reviews and comments
    Posted 06-20-2018 17:40
    Hi ​Harald,
    Thanks for writing into the Community. First, I don't see the report attached, would you like to upload that again? Second, can I rephrase your question? Are you interested in knowing if the Velocity API can get results you are interested in, instead of using embedded queries? Or are you asking if using embedded queries can get you more information than the Velocity API?
    We do have Community Review Center Reports available that our team wrote for Jama; you may want to look through them to see if you can use and or cherry-pick from them:
    Review Center Comments Report
    JamaSoftware/Community-Reports
    Review Center Stats Report
    Review Stats - Reviewers Per Item
    The Review Center Comments Report and the Review Center Stats Report are both available under "Reports" at the top right of any page in Jama.
    Sara Jensen
    Developer Support Engineer
  • 3.  RE: Velocity Report showing reviews and comments
    Posted 06-22-2018 07:28
      |   view attached
    Hi Sara,
    I attached it, maybe I have to put it in a zip archive that it stays.
    The report has been created to fulfill the following needs:
    - show direct at seeing an item all the reviews that happened (also reviews in synched/branched items)
    - comments that have been enetered
    - the relationships, and the description as a tooltip
    This was done to support audits,
    Frequentis AG
    Attachment(s)
  • 4.  RE: Velocity Report showing reviews and comments
    This message was posted by a user wishing to remain anonymous
    Posted 12-03-2018 12:23
    Edited by Phil Bloxom 01-10-2019 13:11
    This post was removed
