Reset Item ID to 1
Jump to Best Answer
  • 1.  Reset Item ID to 1
    Posted 03-29-2017 06:40
    I have imported requirements then delete them. The next time I import new requirements the ID will start with the last requirements ID (even deleted).
    Is there away to reset the sequence of the ID of the item to start with 1?
    Sawsan
    Sawsan Abusharkh
  • 2.  RE: Reset Item ID to 1
    Best Answer
    Posted 03-29-2017 10:37
    Hi Sawsan,
    When you delete an item in Jama, its record from the database is not removed; it is deactivated. Because of this, it is not possible to selectively renumber item IDs. You can change ID numbers and start at a lower number (in this case, one) only if you change the set key.
  • 3.  RE: Reset Item ID to 1
    Posted 03-30-2017 08:34
    Thank you Kristina, your answers are always helpful
    Sawsan Abusharkh
