Rich text formatting not supported on test step > notes field
  • 1.  Rich text formatting not supported on test step > notes field
    Posted 06-05-2019 03:41
    Within a test step, the "Notes" field allows you to apply rich text formatting, but it does not seem to support it; instead, HTML tags are present in the output.
    Nicki
    ZOLL
    Pittsburgh PA
  • 2.  RE: Rich text formatting not supported on test step > notes field
    Posted 06-06-2019 08:06
    Hi Nicki:
    Yes, this is a known defect where the Test runs display HTML tags in steps even though Rich Text is enabled for the field in Test Cases.
    This bug has been logged in our internal system with this ticket and your organization associated to it. For your reference, I have added the bug ID: SOS-DEF-4060. You can check future release notes for this ID to see if this bug has been fixed.
    If you have any questions about our bug fixing process, I recommend reading this article in our community.
  • 3.  RE: Rich text formatting not supported on test step > notes field
    Posted 06-06-2019 08:52
    @Chloe Thank you for your help! ​
    Nicki
    ZOLL
    Pittsburgh PA
