REST API Create Item POST 405 Error
  • 1.  REST API Create Item POST 405 Error
    Posted 12-05-2019 12:07
    I'm trying to write a program in C# using the REST API that reads a word document, generates a list of structures, then creates new items in Jama representing these struct instances. However, running the program results in the line "HttpWebResponse response = (HttpWebResponse)request.GetResponse();" throwing an exception. The exception is: 'The remote server returned an error: (405) Method Not Allowed.' The method that interfaces with Jama is below. What could be causing the problem?
    public void uploadToJama(List<SoftReq> requirements)
        string baseUrl = "https://nz-jama01.fphcare.com/rest/latest";
        // Username and password should be stored according
        // to your organization's security policies
        string username = "API_User";
        string password = "*****";
        int projectID = 46;
        ServicePointManager.SecurityProtocol = ServicePointManager.SecurityProtocol | SecurityProtocolType.Tls11 | SecurityProtocolType.Tls12;
        HttpWebRequest request = (HttpWebRequest)WebRequest.Create(baseUrl);
        request.Method = WebRequestMethods.Http.Post;
        request.ContentType = "application/json";
        string credentials = System.Convert.ToBase64String(System.Text.Encoding.UTF8.GetBytes(username + ":" + password));
        request.Headers["Authorization"] = "Basic " + credentials;
        using (var streamWriter = new StreamWriter(request.GetRequestStream()))
            string json = "{\"project\":" + projectID + ",\"itemType\":137,\"fields\":{\"name\":\"" + requirements[0].name + "\",\"description\":\"" + requirements[0].desc +
                "\",\"trace_id\":\"" + requirements[0].trace + "\"},\"location\":{\"parent\":{\"project\":" + projectID + "}}}";
            streamWriter.Write(json);
        Stream stream = response.GetResponseStream();
        StreamReader streamReader = new StreamReader(stream);
        string s = streamReader.ReadToEnd();
        Console.WriteLine(s);
        Console.ReadKey();
    Jack
  • 2.  RE: REST API Create Item POST 405 Error
    Posted 12-05-2019 13:57
    Jack:
    Does this script work when you use our Swaggar REST API application, or through Postman?
  • 3.  RE: REST API Create Item POST 405 Error
    Posted 12-05-2019 14:20
    Hi Chloe, thanks for the help, I'm very new to REST. I tried the following in Swagger:
      "project": 46,
      "itemType": 137,
      "location": {
        "parent": {
          "project": 46
      "fields": {
        "name": "thing1",
        "description": "thing2",
        "trace_id": "thing3"
    I get a Bad Request error with the message: "Invalid document location. Software Requirement cannot be under project." I was unsure what value to put for item under parent.
    Jack
  • 4.  RE: REST API Create Item POST 405 Error
    Posted 12-05-2019 14:38
    Thanks Jack,
    Which endpoint are you using in Swaggar?
  • 5.  RE: REST API Create Item POST 405 Error
    Posted 12-05-2019 15:25
    Hi Chloe,
    I'm unfamiliar with the term 'endpoint'. I've fixed up the body in Swagger to be as follows:
      "project": 46,
      "itemType": 137,
      "location": {
        "parent": {
          "item": 14403
      "fields": {
        "name": "thing1",
    Now it executes without errors and successfully updates Jama as expected. I've modified the variable 'json' to be as follows:
    string json = "{ \"project\": 46, \"itemType\": 137, \"location\": { \"parent\": { \"item\": 14403 } }, \"fields\": { \"name\": \"thing1\", \"description\": \"thing2\", \"trace_id\": \"thing3\" }}";
    However, I'm still getting a 405 error.
    Jack
  • 6.  RE: REST API Create Item POST 405 Error
    Posted 12-05-2019 15:55
    Hi Jack,
    Looking at your code I can't see where you are adding the endpoint to your URL. Try changing
    to
    string baseUrl = "https://nz-jama01.fphcare.com/rest/v1/items";
    This tells the API to use the "item" endpoint. I also changed "latest" to "v1". Currently "latest" and "v1" resolve to the same thing, but we are making an API change soon that will make a difference to this, so it's just a good practice to start using "v1".
    Everything else looks good. I hope this helps!
    Jason Ritz
  • 7.  RE: REST API Create Item POST 405 Error
    Posted 12-05-2019 17:03
    Edited by Jack Qiu 12-05-2019 17:08
    Hi Jason,
    That seemed to do the trick. I've now changed the string json back to what it should be:
    string json = "{ \"project\": 46, \"itemType\": 137, \"location\": { \"parent\": { \"item\": 14403 } }, \"fields\": { \"name\": \"" + requirements[0].name + "\", \"description\": \"" + requirements[0].desc + "\", \"trace_id\": \"" + requirements[0].trace + "\" }}";
    But now I'm getting a 400 error. Some of the fields have new line characters which have a backslash. Replacing all the newline characters with spaces avoids this error. Is there any workaround without getting rid of the newlines?
    Jack
  • 8.  RE: REST API Create Item POST 405 Error
    Posted 12-06-2019 10:20
    Hi Jack,
    Glad to hear that change worked for you. As for the newline characters, these will break the json format so they do need to be stripped. You can add a line like this to your code to strip the \n's and \r's that are in your string:
    string json = Regex.Replace(s, @"\t|\r", "");
    Hope that helps!
    Jason
    Jason Ritz
