Remove Sample data from the environment
  • 1.  Remove Sample data from the environment
    Posted 09-07-2021 07:12
    Good morning,
    Is there a simple way to remove the sample projects data that come with Jama Connect?  We are building a new environment to clone for User Acceptance Test and Production environments.  Therefore, we do not want any sample data on it.  Thanks,
    Khuemy Nguyen
    Soliel
    Vienna VA
  • 2.  RE: Remove Sample data from the environment
    Posted 09-07-2021 08:14
    Hi Khuemy,
    You can remove any unwanted Projects by navigating to Admin > Projects and selecting them individually from the Projects Tree.
    Before you do so, please review these sections from our User Guide regarding deleting vs archiving Projects.
    Delete a Project
    Archive a Project
    Once a project is deleted, there's no way to restore the project. When a project is deleted, all the data (including attachments that were first uploaded to that project) in that project is deleted. However, this doesn't automatically free up space in the database. A database administrator must manually compact the database.
    As an alternative, you can archive, rather than delete a project, to avoid accidentally removing any other data permanently.
  • 3.  RE: Remove Sample data from the environment
    Posted 09-07-2021 10:49
    If you need to also delete item types, pick lists, editor templates etc... you must FIRST delete the items from the Projects BEFORE deleting the projects.
    Cary Bryczek
