  • 1.  Download Images
    Posted 10-21-2021 08:12
    Hi All!!
    We are trying to download images from Jama text items, text items where properly exported by filtering  the output of:
                    j_proj.jama_client.get_abstract_items(project=j_proj.project_id, item_type=t_id)
    then attachment path has been extracted from text item description
    example: "https://OurUrl/attachment/1234/file.png"
    then we are trying to download the attachment by :
                   jamaclient.get_attachment(attachmentId)
    if
      attachmentId=1234
    then
    this error appears:
    API Client Error. Status: 404 Message: This resource does not exist.
    if
      attachmentId=1234/file.png
    then
    this error appears:
    Do you know what are we doing wrong?
    PS: the image can be download from the web browser using example path.
    Ivan
    Ivan Cejudo Gomez
    Monolithic Power System
    Barcelona
  • 2.  RE: Download Images
    Posted 10-21-2021 12:00
    Hi Ivan,
    I had your same problem in the past.
    If I remember correctly, you have to use the API ID of the attachment in performing GET /attachments/{Id}
  • 3.  RE: Download Images
    Posted 10-21-2021 12:16
    Now!
    Try to use GET /files and pass the the url to the parameters. In the URL you have the attachmentId.
    I hope it helps...
  • 4.  RE: Download Images
    Posted 10-21-2021 23:50
    Hi! Sorry for the delay for reply!
    I think understand the concept.
    I try to:
    -jamaclient.get_attachment(attachmentID) ->Error resource not exist
    -jamaclient.get_attachment(attachmentID/file) ->Error resource not exist
    -jamaclient.get_attachment(attachmentID/files) ->Error resource not exist
    -jamaclient.get_attachment(ALL_URL/attachmentid/file)-> 500 Server error
    -jamaclient.get_attachment(ALL_URL/attachmentid/files)-> 500 Server error
    -jamaclient.get_attachment(ALL_URL/attachmentID)-> 500 Server error
    When you say GET /files ... you mean that?
    Thanks!!
    Rewards!
    Ivan.
    Ivan Cejudo Gomez
    Barcelona
  • 5.  RE: Download Images
    Posted 10-22-2021 00:35
    Edited by Alessandro 10-22-2021 00:41
    Good morning Ivan,
    it is another endpoint of the REST API.
    You'd better to test with swagger -> you can see all the endpoints ;-)
    Swagger
    For the available endüpoints you can give a look here : https://dev.jamasoftware.com/
  • 6.  RE: Download Images
    Posted 10-22-2021 01:41
    Edited by Ivan 10-22-2021 03:20
    Yes.
    Check the documentation at https://dev.jamasoftware.com and read endpoint get / attach / attachid / file to download images, but in my script they show errors (in the post above), I don't see practical examples and I don't know how focus / do it.
    Sorry for the lost time!
    PD:Using Python!
    Rewards
    Ivan.
    Ivan Cejudo Gomez
    Barcelona
  • 7.  RE: Download Images
    Posted 10-22-2021 07:01
    You have to build your own function if not available -> check Swagger and build the GET accordingly
    Suggestion :
    • imageurl = jamurl + '/attachment/' + id + '/' + filename
    • resource_path = 'files'
    • params = {'url' : imageurl}
    • response = jama_client._JamaClient__core.get(resource_path, params)
    • respose.content should be the image that can be stored in a file.
    It should work...
  • 8.  RE: Download Images
    Posted 10-22-2021 07:06
    Ty Alessandro!!!
    Very very thanks!
    Finally got it!!
    Rewards!
    Ivan
    Ivan Cejudo Gomez
    Barcelona
