Hi Chloe,
we already have several custom fields created in a test cycle, that just contain information about a test cycle, that we are using for filtering purposes and for generating Velocity reports. At the moment we cannot edit or delete those.
Our Test Team had some ideas to add additional fields for similar purpose, i.e. they would not need to provide any additional functionality than just displaying the information in cycle view details page. And another idea was to add a template to a test cycle description field.
Thanks a lot,
Ekaterina Kessner
MeVis Medical Solutions AG
Sent: 06-07-2019 11:44
Subject: Edit and add custom fields on Test Cycle
Ekaterina:
How are you wanting to use these custom fields? Do you just need them there to inform or do you want them to interact with the Test Center process in someway? I ask because if you just need to inform, we might be able to figure something out - depending on what you need to do. But if you need these custom fields to actively trigger functionality within the Test Center, this will most likely not be possible.
If you are able to tell me a little more about what functionality you are trying accomplish, I would love to brainstorm this with you.
Sent: 06-07-2019 05:27
in Jama versions after 8.10 there is no possibility to edit or add custom fields on Test Cycles. We have some custom fields that our users wished to change and we are not sure how to do it.
We are running 8.25 and validating 8.36, in both versions this feature is unavailable.
Ekaterina
