"User Comments" field in tab "Versions" of an item
  • 1.  "User Comments" field in tab "Versions" of an item
    Posted 11-20-2019 05:48
    Hello !
    I have a question about a field "User Comment" that is here in the tab "Version" of an item. How is this possible to edit it ? I didn't find the way to use it.
    Samuel LE COZE ULSHYNA
    Mercury Missions System Intl
    Geneva
  • 2.  RE: "User Comments" field in tab "Versions" of an item
    Posted 11-20-2019 09:47
    Hi Samuel:
    Welcome to the Community!
    This window shows information on the versioning post update (this is a version history where you can compare versions) and is not editable from this vantage point in the UI. During the update/edit process one can "Notify" other users (using the "Save and Notify" option) or just add a general comment that will get recorded there.
    Samuel, I linked the coordinating User Guide information within this post, hope this helps, let me know if you have any further questions.
  • 3.  RE: "User Comments" field in tab "Versions" of an item
    Posted 11-21-2019 07:23
    Perfect, you answered totally my question !! In the userguide I read before asking my question, I did not see clearly the point.
    Just think to update this guideline, adding that this notified comment will fill the "UserComments" from "Versions".
    Thank you !
    Geneva FM
