Session timeout time limit
  • 1.  Session timeout time limit
    Posted 14 days ago
    How long does the application needs to be idle before a user is logged out or a session expires?
    Lakshmi Kunnathur
  • 2.  RE: Session timeout time limit
    Posted 13 days ago
    The default session timeout is 120 minutes but this can be changed by an administrator if they log in as root user and edit the Session Timeout field under System Properties.
    https://help.jamasoftware.com/ah/en/administration/system-administrator/set-up-the-application/configure-general-properties.html
    Alex
    Fujifilm Sonosite
  • 3.  RE: Session timeout time limit
    Posted 13 days ago
    Hi Lakshmi,
    Thank you for reaching out! The time out settings can vary depending on what your Organizational Admin has arranged with Tech Support.
    Please check with your Org Admin for this information.
