It is still not possible, right? We also would like to reuse older baselines, because not every project should start with the newest requirements set. I'm talking about organisational and regulatory requirements, not functional product requirements, and sometimes the customer requires a historic version due to other long running projects.
So instead of baselining we should branch by making a copy, right?
Ralf Bürger
SSE for KoDeCs
Hattingen
00491722000771
Sent: 03-21-2017 12:57
Subject: Reuse from version or baseline
Hi Tom!
A. No, it's not—reuse always occurs from the current version.
B. It is not. You would have to revert the items to the baseline state and then reuse.
Sent: 03-21-2017 13:59
Question A:
Is it possible to reuse an item from a particular version in its history?
Question B:
Is it possible to reuse a collection of items from a baseline?
In each use case, content in the "old" version is what's desired to be present in the resulting "re-used" item.
Tom Green
Thermo Fisher Scientific
