Unmet start requirement:
  • 1.  Unmet start requirement:
    Posted 10-05-2018 02:58
      |   view attached
    Good day,
    I followed the Jama installation guide.
    I have two virtual machines running Centos 7
    One for Jama Admin
    the other for Mysql
    Evertyhing went ok and I had to import the license file.
    But when I try and start Jama I get an error:
    Unmet start requirement: License requires at least 1 node to be connected, found 0.
    I have checked and it appears all docker processes are running.
    I can resolve all dns names
    The mysql tests pass in the settings section of the Dashboard.
    Can someone kindly tell me what I am doing wrong and where to look for an answer to this issue?
    Alan Rolfe
    Incomar
    SLP
  • 2.  RE: Unmet start requirement:
    Posted 10-05-2018 10:06
    Alan:
    Thank you for posting on the Community. My resources say that this error is most likely triggered by Firewalld blocking Replicated communication with a main operation node. If this sounds accurate, you will want to disable your firewall, when you install Jama. Then you are going to want to make sure that your firewalld is configured to play nice with Jama.
