Project-specific seach criterium?
  • 1.  Project-specific seach criterium?
    Posted 07-11-2018 04:57
    Hi everyone,
    one of our users has the request to see certain items in *many* projects and has asked if Search was able to do that. He is aware that he can search in certain project, in the current project or in all projects - but would he be able to able to search in projects A, C and E, and not in project B and D?
    I wasn't able to find a solution to that use case, does anyone have an idea how this can be achieved?
    Anna Henke
  • 2.  RE: Project-specific seach criterium?
    Posted 07-11-2018 05:25
    After having posted this I became aware of the possiblity to filter search results - this brings up the possibility to select certain projects when having selected "All projects" in the filter before.
    This would be a reasonable workaround, if identifing the projects in the filter itself is not possible.
    Anna Henke
  • 3.  RE: Project-specific seach criterium?
    Posted 07-11-2018 05:29
    You can use the ID field to filter for specific projects. Alternatively this can also be achieved by Lucene statements in keywords.
    Harald Hotz-Behofsits
    Frequentis AG
  • 4.  RE: Project-specific seach criterium?
    Posted 07-11-2018 11:10
    Anna:
    Yes, you found a good workaround for your use-case. Doing a Search across all projects and then Filter the results for A, B, D project; excluding C and E projects!
    Business Support Engineer
