I'd like to find out expected behavior on an issue reported by a user. We just upgraded our production environment form 2015.3 to 8.14.1.
When the user has multiple items synchronized and they go to make a change to one of their synced Test Cases (say the description), we are not seeing the Sync Status change to Out of Sync after committing the change. It will stay at In Sync. They then have to either press the refresh button, or click out of that Test Case, and back into it in order for the Sync Status column to change to Out of Sync. They can then re-sync successfully and they are good to go until they make another change, and have to repeat the process.
Is this expected behavior for that column, or should it automatically update to Out of Sync after saving the change? Any help is appreciated!
Josh
