Review testplan does not include test cases anymore (Jama Connect 8.65)
  • 1.  Review testplan does not include test cases anymore (Jama Connect 8.65)
    Posted 17 days ago
    LS
    Since we run Jama Connect 8.65 (Cloud version) we see an issue in reviewing test plan:
    When one creates a review for a test plan that contains test cases, the review which will be created will not contain any of the Test Cases which are assigned to the test plan. This used to work fine, in previous versions.
    Is there something changed or can we work around this issue?
    Kind regards
        Hans Lieftink
    Hans Lieftink
    Thermo Fisher Scientific
    Eindhoven
    0031623514844
  • 2.  RE: Review testplan does not include test cases anymore (Jama Connect 8.65)
    Posted 17 days ago
    Hi Hans,
    Thank you for reaching out about this! Based on your description, it sounds like you've encountered a defect known as:
    SOS-DEF-5570 Test Plan: Send for Review button does not include the Test Cases
    The workaround for this issue is to right-click Test Plan from the left-hand navigation and select Send for Review.
    Example:
    Please note that we are expecting the fix for this defect to be included in the 8.66 Release.
    This can be confirmed in the Resolved Issues section of the Release Notes once they are published.
