Has anybody seeing the following problem?
A
bar chart is not displaying correctly all the data. I am trying to display "Requirements" by "Capability Areas", and not all the Capability Areas are displayed. However, the Capability Area are correctly associated to the Requirements, when checking Requirements individually.
Here is what I tried:
- Bulk import (Excel file) of the requirements with the mapped capability areas. Result: Not all the capability areas were displayed on the bar chart. However, the data was there.
- Deleted everything and started over.
- Split the data in several Excel files for each Capability Area and started importing one file at a time. I imported successfully 2/3 of the files. Then after importing one new file, that particular Capability Area did not show in the bar chart (but again the data was correctly associated to the requirements). Not only the latest Capability Area did not show on the bar chart, but other Capability Areas (previously displaying) started not to display on the bar Chart.
Has anybody seen anything like that? Is this a rendering problem of the filter? Is there a limit for the items to be displayed? I believe I'm using JAMA version 8.20-OP. Year 2017.
Francesca
