  • 1.  'include' in '/items' or '/abstractitems'
    Posted 01-23-2020 03:05
    I try to get item links using 'include' parameter but I do not manage to understand what shall be the content of the 'include' parameter. And I've not found any example.
    I've tried following without any success:
    • include=5
    • include=Related%20to
    • include=*
    • include=relationship.Related%20to
    Could somebody help me to find the right parameter value ?
    Thank you in advance.
    Christophe
  • 2.  RE: 'include' in '/items' or '/abstractitems'
    Posted 01-24-2020 10:06
    Hello @Christophe
    I consulted with one of our Developer Support Engineers and here is the insight:
    Examples include the links part of the json response. For example in the response body for /items it has the following below. so you can have data.createdBy as an include parameter, if you do a GET /items it includes the users that those items were created by. example usage is here as well: https://dev.jamasoftware.com/cookbook/#include-parameter
    "links": {
        "data.createdBy": {
          "type": "users",
          "href": "https://jama-jphang.jamacloud.com/rest/v1/users/{data.createdBy}"
        "data.childItemType": {
          "type": "itemtypes",
          "href": "https://jama-jphang.jamacloud.com/rest/v1/itemtypes/{data.childItemType}"
        "data.lock.lockedBy": {
          "type": "users",
          "href": "https://jama-jphang.jamacloud.com/rest/v1/users/{data.lock.lockedBy}"
        "data.fields.lookup4": {
          "type": "picklistoptions",
          "href": "https://jama-jphang.jamacloud.com/rest/v1/picklistoptions/{data.fields.lookup4}"
        "data.modifiedBy": {
          "type": "users",
          "href": "https://jama-jphang.jamacloud.com/rest/v1/users/{data.modifiedBy}"
        "data.location.parent.item": {
          "type": "items",
          "href": "https://jama-jphang.jamacloud.com/rest/v1/items/{data.location.parent.item}"
        "data.fields.lookup1": {
          "href": "https://jama-jphang.jamacloud.com/rest/v1/picklistoptions/{data.fields.lookup1}"
        "data.project": {
          "type": "projects",
          "href": "https://jama-jphang.jamacloud.com/rest/v1/projects/{data.project}"
        "data.fields.lookup2": {
          "href": "https://jama-jphang.jamacloud.com/rest/v1/picklistoptions/{data.fields.lookup2}"
        "data.fields.modifiedBy": {
          "type": "users",
          "href": "https://jama-jphang.jamacloud.com/rest/v1/users/{data.fields.modifiedBy}"
        "data.itemType": {
          "href": "https://jama-jphang.jamacloud.com/rest/v1/itemtypes/{data.itemType}"
        "data.location.parent.project": {
          "type": "projects",
          "href": "https://jama-jphang.jamacloud.com/rest/v1/projects/{data.location.parent.project}"
  • 3.  RE: 'include' in '/items' or '/abstractitems'
    Posted 01-24-2020 13:34
    Edited by Christophe 01-24-2020 13:36
    Thank you @Chloe for this fast answer.
    Can you tell me whether it is possible to get relationships using this 'include' parameter ? I do not see any relationship in your example.
    Christophe
  • 4.  RE: 'include' in '/items' or '/abstractitems'
    Best Answer
    Posted 01-27-2020 06:57
    Hi Christophe:
    I double checked and Relationships is not something which can be pulled in with the Include param. We do have a whole Relationship endpoint but, I can see how it would be faster with Include.
  • 5.  RE: 'include' in '/items' or '/abstractitems'
    Posted 10-16-2021 11:18
    So what is the best way to get specific relationtypes for specific jama items?
    My query is something like this: get_relations where jama_item in ( item_types) and relation_ship in (relationship_types)
    I am trying to fetch relationships based on a specific name for items that of interest. I can see how easy it is to pull all the information i need using abstract items and include option. But it looks like include does not support including relationships in abstract items. Is this something that will be supported in the future?
    Alternatively, a search filter in "/api-docs/#/relationships/getRelationships" can also do that trick so at least i can filter the search based on relation ship name and then further perform a client based filter for the relations i need.
    Kishore Vanapalli
